Monthly calculation
Hello,
I would like to ask for your support in creating correct measure.
The task is to calculate the cost to be paid per device per month.
We have commission 6,5% and compare it to minimum rent.
If commission is lower then rent, we pay rent, if above we pay commission.
Attached represents the logic:
In Jan highlighted device haven’t reached rent minimum, but it done it on Feb
1
My current (incorrect) measures are as follows:
2
And SUMX to represent correct totals:
Now the problem is that I haven’t specified the fact that logic should apply to data related to months.
So, if I remove months filter from columns, I will end up with no added 74zl due to the fact that value of commissions for those 2 months doesn’t surpass rent value.
4
Any ideas how this can be resolved?
Thank you, have a nice day :blush:
Hello @DanDer
That would be great If you can add a demo PBIX file so that we can see the Data Model.
But try this measure for your Cost SUMX .
Cost SUMX =
  SUMX (
            SUMMARIZE ( 'ATM master',
                        'ATM master'[ATM ID],
                        'Dates' [Month],
                        "rent_new", Rent[Cost]),
            [rent_new] )
If i does work. Please mark this a solution. Otherwise, try to send us a pbix demo so that we can see how your model is structured.
Hi @DanDer, did the response provided by @HASSAN_BI help you solve your query? If not, we are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Thank you @HASSAN_BI for getting back to me.
Unfortunately solution didn’t do the trick.
I’ll provide more details on case including masked file this weekend, so please do not close the thread just yet. I appreciate you help so far
Regards, Dan
Hi @DanDer! We noticed that your inquiry was left unsolved for quite some time now. We strive to answer ALL inquiries in the forum. However, if you are sure that you provided all pertinent context to your concerns and read how to use the forum more effectively and still find your question unanswered, you can check out tutorials to learn this yourself as your membership also comes with relevant resources that may help you with your Power BI education.
