I notice that ‘Direct Query’ is the only method that works for Data Storage Mode.
The report pages refresh incredibly slowly, so I would prefer to use ‘Import’ for Data Storage, so that I have a local copy of the data in the PBIX file, instead of the ‘Direct Query’ method.
I have tried switching from ‘Direct Query’ to ‘Import’ mode, so that the data is loaded into memory, but I get nothing in the ‘Data’ pane. In fact, the data in my reports disappear once I switch to ‘Import’ mode.
Can you please provide the steps that you’ve followed to convert it from DirectQuery to Import?
Secondly, if possible can you create a copy of that file and re-import the data and check whether the data is getting perfectly loaded into that file? Also if the data gets loaded you can try deleting the old query and connect it with the newly loaded data.
I have checked the Microsoft Blog and it clearly states we can only use Direct Query with Microsoft Call Quality Beta Connector.
The reason it’s not working on changing to Import as it is not supported. Don’t think we can help here as it is connector limitation. We can only provide information on this that is available on Internet
Hi Ankit - thank you for this. I agree, it’s a connector limitation. If you know of anyone that is pulling data from MS Teams in another way, please let me know.
Hello @anonymous316, and thank you for submitting your question to the Community Forum. The post you are trying to add to has been closed and resolved for almost three years. Therefore, would you kindly close this post and create a new one with your question. Please refer to the previous post by adding this URL: Microsoft Call Quality and CQD dashboards - #5 by Floyd as a link in the fresh post.
