Hi All
Working with Micros and Sage systems (F&B outlet). How easy is it to integration PBI into these systems to pull live data? And how do I go about doing so?
Stu
Hi All
Stu
Hi @Stuart, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @Stuart, we’ve noticed that no response has been received from you since the 22nd of November. We just want to check if you still need further help with this post? In case there won’t be any activity to include the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details, in the next few details we’ll be tagging this post as Solved. Thanks!
