Wondering if anyone can assist. I have 2 queries (Source & Destination).
I want to Left Join Destination to Source, however I want to merge upto a certain step in the Source to avoid breaking the Query Fold in the destination. Just wanted to know if this is possible and how would I go about doing this?
Hi Ashton,
you want to avoid breaking the query fold.
=> Here is a minimal invasive approach for you:
You can reference steps in another query with Metadata.
Add a metadata record after the final step of the query:
AddedMetadata = FinalStep meta [RefName= StepName]
You can reference to it like this:
= Value.Metadata(QueryName)[RefName]
Thanks for posting this. This is exactly what I am after. Having downloaded the sample file and using the suggested method to join the tables (I created an index in both tables)
I ran some tests this morning using sample data online and the function definitely works in the Dataflow.
I then reviewed my query and after going each step I got it work. For some reason which I am not clear yet, it had something to do with a Referenced Query. Having changed the steps in the Referenced Query seemed to do the trick.
