Measures Total doesn't work
Hello all-
I watched at least 10 videos about fixing a Measure Total.
But it didn’t work.
I have a quantity in one table and amount in another.
If quantity is bigger then 900 I have to calculate 0.005% of the amount.
Should be rather simple:)
However, my total always ignoring >900, even the rows amounts are OK.
Please help!
Thank you!
Natasha
Instacart1.pbix (14.8 MB)
Hello @npower,
Below are the mesures alongwith the screenshot of the final results provided for the reference -
YN 0.5% - Totals =
SUMX(
    SUMMARIZE(
        Tlog ,
        Tlog[Site] ,
        "@Totals" ,
        [YN 0.5%] ) ,
    [@Totals] )
Value Disc 0.5% - Totals =
SUMX(
    SUMMARIZE(
        Tlog ,
        Tlog[Site] ,
        "@Totals" ,
        [Value Disc 0.5%] ) ,
    [@Totals] )
I’m also attaching the working of the PBIX file alongwith the link of the post provided below for the reference which is being created by our in-house expert which specifically addresses this type of issue.
Note: In order to view the entire post, please click onto the link and not onto the “expand/collapse” button.
Thanks and Warm Regards,
Harsh
Instacart1 - Harsh.pbix (14.8 MB)
Dear Harsh!
It works! Thank you very much for your quick and proper response!
Can you please explain to me the meaning of “@Totals” in your measures?
Does it ask to look into Totals?
Thank you very much again!
Tlog ,
Tlog[Site] ,
@Totals” ,
Hello @npower,
You’re Welcome!!!
Lastly, the meaning of “@Totals” is that it creates the virtual column inside that measure and then it sums up that column and then evaluates the results.
Harsh
Wow! Thank you very much!
