I find myself a bit stuck on perhaps two simple task.
I have a PBI that needs to do two things:
Task 1 -
- Make a measure that can be added to any column, that will do this…
- Sum all values >=4,
- then divide by total rows
Task 2 -
- Use the SupportFile as a support table
- Group the columns from the Results file by the criterial form the SupportTable file.
For example, all columns from 1-3 in Results file will be grouped in “Overview” because they match with the “Sort” column in SupportTable file.
Any type of support will be greatly appreciated.
Sample.zip (68.6 KB)
@emercado777 Not sure if this is what you want?!
Sample.pbix (57.3 KB)
Table =
VAR TotalBySort =
ADDCOLUMNS (
DISTINCT ( Results[Column] ),
"Sort",
CALCULATE (
VAR Total =
SUMX ( Results, Results[Value] )
VAR RowCount =
COUNTROWS ( Results )
DIVIDE ( Total, RowCount ),
Results[Value] >= 4
VAR GetDescription =
ADDCOLUMNS (
TotalBySort,
"Description",
VAR CurrentSort = Results[Column]
VAR DescTable =
CALCULATETABLE (
DISTINCT ( 'Description'[Category] ),
'Description'[Sort] = CurrentSort,
REMOVEFILTERS ( Results )
CONCATENATEX ( DescTable, 'Description'[Category], ", " )
VAR GroupRows =
GROUPBY (
GetDescription,
'Description'[Description],
"Something", SUMX ( CURRENTGROUP (), [Sort] )
GroupRows
Hi @AntrikshSharma ,
Thanks for having a look.
However, the total number of respondents should be 123, but in the file you sent over it says 1845.
I think your file is aggregating each response per category, instead of counting each row separately (i.e. counting the number of email addresses)
Hi @emercado777! We noticed that your inquiry was left unsolved for quite some time now.
Hi
Thanks for letting me know.
As for the solutions, I opted for a long but simple solution.
For task 1:
A01 = CALCULATE(
[Total Respondents],
SurveyResults[A01] >= 4)
Where “A01” would need to be updated based on the column’s name.
