Measure is disrupted by display context
Product _ Gross Margin - Issue.pbix (1.2 MB)
Budget Data _offline.xlsx (14.6 KB)
Fact Table.xlsx (5.6 MB)
Forecast Data _offline.xlsx (15.2 KB)
Hello @mdalton2100,
To achieve the results based on the criteria that you’ve specified. Below is the measure alongwith the screenshot of the final results provided for the reference -
Flux % - Cost of Services (Actuals) - Harsh =
----- Cost of Services Calculation -----
VAR Actual_CQ_Revenue =
    CALCULATE( [Actuals (+/-)] ,
        FILTER( 'Gross Margin transactions' ,
            'Gross Margin transactions'[Gross Margin element] = "Products Revenue" ) ) ,
    'Mapping for Flux analysis only'[Gross Margin group_Level 0] = "Revenue" )
VAR Actual_CQ_CoSvces =
    CALCULATE( [Actuals (Flux) CQ] ,
        FILTER( 'Mapping for Flux analysis only' ,
            'Mapping for Flux analysis only'[Flux Category] = "Cost of Services" ) ) ,
VAR Actuals_PQ_Revenue =
        'Mapping for Flux analysis only'[Gross Margin group_Level 0] = "Revenue" ) ,
    DATEADD( Dates[Date] , -1 , QUARTER ) )
VAR Actuals_PQ_CoSvces =
        'Mapping for Flux analysis only'[Flux Category] = "Cost of Services" ) ,
VAR Actual_CQ_CoSvces_Ratio =
DIVIDE( Actual_CQ_CoSvces , Actual_CQ_Revenue , 0 )
VAR Actuals_PQ_CoSvces_Ratio =
DIVIDE( Actuals_PQ_CoSvces , Actuals_PQ_Revenue , 0 )
----- Mfg Spend Calculation -----
VAR Actual_CQ_Mfg_Spends =
        'Mapping for Flux analysis only'[Flux Category] = "Mfg Spend" ) )
VAR Actuals_PQ_Mfg_Spends =
        'Mapping for Flux analysis only'[Flux Category] = "Mfg Spend" ) ) ,
VAR Actual_CQ_Mfg_Spend_Ratio =
DIVIDE( Actual_CQ_Mfg_Spends , Actual_CQ_Revenue , 0 )
VAR Actuals_PQ_Mfg_Spend_Ratio =
DIVIDE( Actuals_PQ_Mfg_Spends , Actuals_PQ_Revenue , 0 )
----- Results -----
SWITCH( TRUE() ,
    SELECTEDVALUE( 'Mapping for Flux analysis only'[Flux Category] ) = "Cost of Services" ,
        ABS( Actual_CQ_CoSvces_Ratio - Actuals_PQ_CoSvces_Ratio ) ,
    SELECTEDVALUE( 'Mapping for Flux analysis only'[Flux Category] ) = "Mfg Spend" ,
        ABS( Actual_CQ_Mfg_Spend_Ratio - Actuals_PQ_Mfg_Spend_Ratio ) ,
    SELECTEDVALUE( 'Mapping for Flux analysis only'[Flux Category] ) = "D C" ,
        BLANK() ,
    SELECTEDVALUE( 'Mapping for Flux analysis only'[Flux Category] ) = "Material CoGs" ,
        BLANK() ,
    SELECTEDVALUE( 'Mapping for Flux analysis only'[Flux Category] ) = "Mfg OH CoGS" ,
        BLANK() ,
    SELECTEDVALUE( 'Mapping for Flux analysis only'[Flux Category] ) = "Products Revenue" ,
        BLANK() ,
    SELECTEDVALUE( 'Mapping for Flux analysis only'[Flux Category] ) = "GAAP Adjustment" ,
        BLANK() ,
    SELECTEDVALUE( 'Mapping for Flux analysis only'[Flux Category] ) = "Revaluation" ,
        BLANK() ,
    SELECTEDVALUE( 'Mapping for Flux analysis only'[Flux Category] ) = "Services Revenue" ,
        BLANK() ,
        ABS((  Actual_CQ_CoSvces_Ratio - Actuals_PQ_CoSvces_Ratio ) + ( Actual_CQ_Mfg_Spend_Ratio - Actuals_PQ_Mfg_Spend_Ratio ) ) )
Thanks and Warm Regards,
Harsh
Product _ Gross Margin - Issue - Harsh.pbix (1.2 MB)
Thank you so much for that detailed answer @Harsh
We hope this helped you @mdalton2100 :slight_smile:
Hi @mdalton2100, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
Kindly take time to answer the Enterprise DNA Forum User Experience Survey, we hope you’ll give your insights on how we can further improve the Support forum. Thanks!
Sorry for the delay reply. Yes, this solution was effective! Thanks again.
