Measure group hours by week
Here is my PBIX file and solution file example:
I have people with hours worked for each day. I want to group by week (ending Friday and starting Saturday) then sum hours for each person. See column D for solution example:
This measure isn’t summing how I expected and the output isn’t right. What is best way to do this?
hi @izzleee,
Made some small changes to your measure, give this a go:
sum_weekhrs v2 =
    var selperson = VALUES('sample'[person])
    VAR startOfWeek = VALUES( Dates[WeekStartingSaturday] )
    var result =
        SUM('sample'[hrs]),
        'sample'[person] IN selperson,
        'Dates'[WeekStartingSaturday] IN startOfWeek,
        REMOVEFILTERS( Dates[Date] ), REMOVEFILTERS( 'sample'[hrs] )
    return result
With this result
Note you don’t need REMOVEFILTERS( ‘sample’[hrs] ) if you remove that field from the table visual.
I hope this is helpful
Thanks @Melissa ! You seem to know everything. Always really appreciate your answers.
