I have a table as displayed below, where I need a DAX Measure or two Custom columns that will give me the MAX Date and the Column Name it came from. I want to create a value that will give me the Max Date and Column name in the Row.
I can create a Custom Column to get the Max Date, but I need to also return the column name in another column.
Hi Sam, I can unpivot the table no issues, but then I only want to keep one row for each and remove the rest from the Table, this is the challenge I have.
Hi Sam, I know I could filter the DAX measures based on MAX date, but I would have to do this for every DAX calculation, as I only want to keep the row in the table with the MAX date as I’m not interested in any of the other rows as all the columns are exactly the same.
There are 20 columns in the table and I need the Column Name and value of the MAX date to be represent in a two columns, 1 Column called “Stage Name” and the Other with “Stage Date”. If I unpivot the columns named Stage 1 Date to Stage 7 Date, I will end up with multiple rows containing the other 13 colums where there was multiple dates is the columns Stage 1 to Stage 7 Date. I only require one row.
In the example table I provided, if I unpivot, I will end up with 3 rows.
Row #; Stage Name; Stage Date; Other Columns in Table.
9;Stage 3 Date;03/10/2016; Other Columns from same Row in Table
9;Stage 4 Date;28/06/2016; Other Columns from same Row in Table
9;Stage 5 Date;19/10/2016; Other Columns from same Row in Table
In the above example, I only wish two Keep the first Row as that’s the one with the MAX date and I also have the Stage name (Stage 3) that contained the Max Date.
In the other columns I have as Total Value for that row, so if I end up with three rows, then the total value will be tripled. I want to avoid have to filter all the rows in the DAX Measures just to include the one row with the MAX date, which is why I just was to delete all the other rows from the Table.
Maybe this is not as simple as I thought it would be?
What you need to do is create 2 tables here, 2 fact tables.
One would be with all the detailed data as is now, then you want to break out the Stage information into another tables and unpivot that. So you will just have the staging information in one single table.
You then need to create a lookup table which can link the two and create the correct filtering that you require.
What would be an appropriate index that could work across these two tables and basically become the link between them as a lookup table?
I’m pretty confident this is what you need now.
I’ve worked with this scenario one time from memory but was for a client so I don’t have a specific example for you.
Is this making sense, solving this in the model…
In the Custom Column, I get the MAX date from the selected columns in the row context. I need a new column that will give me the Column Name, and if there are two dates of the same value, it will return the earliest Column Name.
Take Row 3 with Opportunity ID of 3. The MAX List Date = 6th July 2020, but as this is matching in both Columns “Stage 1” and “Stage 2” the results should be given as Stage 1.
Take Row 2 with Opportunity ID of 2. The MAX List Date = 7th October 2021, but as this is match in both Columns “Stage 3” and “Stage 5” the result should be given as Stage 3
Take Row 1 with an Opportunity ID of 1. The MAX List Date = 8th March 2020, and as there is only one date matching the MAX List Date, the result will be give as Stage 4
In future please create a new topic and just reference the old one if that’s required for additional context. See if this meets your requirement. Just paste the code into a new blank query.
let
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("VY7RDQAhCEN34dukgnq6i3H/Nc7Gw3AJH69QCnOKSpJbAwWWLVOtNMU2KCp79DU0xw7Nzj/JtbI7D7pHBfyKpnp4HwzDjnFTaWrhNV7wb9d6AQ==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Opportunity ID" = _t, #"Stage 1" = _t, #"Stage 2" = _t, #"Stage 3" = _t, #"Stage 4" = _t, #"Stage 5" = _t]),
ChType = Table.TransformColumnTypes(Source,{{"Opportunity ID", Int64.Type}, {"Stage 1", type date}, {"Stage 2", type date}, {"Stage 3", type date}, {"Stage 4", type date}, {"Stage 5", type date}}),
GetMax = Table.AddColumn(ChType, "Custom", each List.Max( Record.ToList( Record.RemoveFields( _, "Opportunity ID" )))),
GetName = Table.AddColumn(GetMax, "ColName", each Record.FieldNames(_){List.PositionOf(Record.FieldValues(_), [Custom])})
in
GetName
@Melissa , this works great, but in reality I have around 20 columns in my table, so how should I update this to only include columns starting with "Stage " as a Column Name
Okay, give this a go instead. Just paste the full script into a new blank query.
I’ve added a ListStages variable that identifies the Column-/Fieldnames starting with “Stage”
let
ListStages = List.Select( Table.ColumnNames(Source), each Text.StartsWith( _, "Stage", Comparer.OrdinalIgnoreCase )),
GetMax = Table.AddColumn(ChType, "Custom", each List.Max( Record.ToList( Record.SelectFields( _, ListStages )))),
GetName = Table.AddColumn(GetMax, "ColName", each Record.FieldNames(Record.SelectFields( _, ListStages )){List.PositionOf( Record.ToList( Record.SelectFields( _, ListStages )), [Custom])})
in
GetName
