I have an issue with matrix visual and I need help.
Here is a picture of the Desired state :
Here is what I managed to visualize:
I am using a DAX measure to find the 2nd channel by its value.
I can’t find if the DAX measure should be improved or the matrix organization to be able to achieve the wanted visual state.
Here is the pbi file with sample data:
sample-for-forum.pbix (3.6 MB)
Here are the tables for the pbi file.
PowerBI-data-forum.rar (916.1 KB)
Thanks a lot!
Radost
Hi @radost_ilieva, while waiting for other members to jump in, I suggest using the forum search to discover if your query has been asked before by another member. Thanks!
Hi @radost_ilieva! We noticed that your inquiry was left unsolved for quite some time now.
