Matrix to show by month and also by year for 2 years
Is there a way of the matrix showing a monthly value and annual total over a 2 year period. As per the attachment.
sample.xlsx (10.9 KB)
Thanks in advance
E
*** READ FIRST ***
Before you send your question.
Make sure that all details relevant to your question is complete:
  • Your current work-in-progress PBIX file - VERY IMPORTANT
  • A clear explanation of the problem you are experiencing
  • A mockup of the results you want to achieve
  • Your underlying data file
Also make sure that your data file contains no confidential information. If it does, click the link above.
*** DELETE THIS MESSAGE IF YOU ARE SURE ALL YOUR DETAILS ARE COMPLETE OR IF THE ABOVE INFORMATION IS NOT APPLICABLE TO YOUR QUESTION.***
Hello @ElizabethTachjian,
In order to achieve the results based on the scenario that you’ve provided in the Excel mock-up file. You’ll be required to break the figures first, by “Fiscal Year” and then add another layer beneath that of field “Month & Year” so that you’ve intermediate totals for each year.
Below is the screenshot of the final results alongwith the working of the PBIX file attached for the reference -
Thanks and Warm Regards,
Harsh
Matrix Visualisation - Yearly Bifurcation of Figures - Harsh.pbix (102.5 KB)
Thank you. I will review now.
Working beautifully. thank you!
You’re Welcome! :slightly_smiling_face:
Harsh
