I have a 7 level category that i need to drill down in a matrix, my question is if it’s possible to do the expand to the next hierarchy only for 1 particular column and the other columns remains unexpanded?
Thanks in advance!
Kind regards,
Aracelli
I believe so. You just use the drill down and up buttons that are in the visual.
Have you given this a try?
Thanks. Yes, i have tried that but that will drill down the particular column that has been clicked and the others will disappear.
Actually, what i would like is to be able to drill down the particular column and the other columns stay. Do you know if that is possible?
Thanks!
Aracelli
Hi
Have you tired below
Right the column and select Drill down. Only that column will be drilled down.
Thanks Namjan,
Yes but i use that , the other initial columns disappear.
Hi
Yes I saw that functionality. I think that the limitation. Don’t know for sure.
Yes ok I understand better now. I just am not sure this is possible right now. I’ve had a quick play around myself and couldn’t find a way to do this.
Hello,
Actually I found that this is possible with the rows and there is a current idea under review to do the same for the column headers:
https://ideas.powerbi.com/forums/265200/suggestions/36038050
Do you think the members of the Enterprise DNA community can vote in order to make this a reality?
Thanks in advance!
Kind regards,
Aracelli
Right, yep I knew you could do that with the rows. It’s a great addition.
Yes I agree would be great for columns as well. I’m sure it’s not far away.
