Well, I can see the Basic Labs Assessment Survey but I am not able to locate the Labs I should do to be able to answer the survey properly. Could anybody give a hint about their names?
Thanks!
Thanks!
where are you are seeing this Basic Labs assessment Survey?
Can you please provide a screen print where are you seeing this?
thanks
Keith
sorry i still can’t find that. Looks like its a course that has that module in it. Can you please give me that course where that is?
Sure!
The course name is Mastering DAX Calculations.
sorry i can’t figure out the labs. I believe it related to the download files at the beginnging of the course. The files are likely used in demos within the course modules. Its been a while since i taken that course.
@EnterpriseDNA will have to answer that for you.
thanks
Keith
Thanks @Keith . I hope @EnterpriseDNA can bring some light into this!
