For United States, I would like to drill down to USA -->State -->Zip Code, for international, I would like to go country -->city -->zip code.
Please refer attachment for sample data.
sample_data.csv (702 Bytes)
Hi, could you provide a pbix including international addresses. Interesting, you can drilldown using a hierarchy so you need multiple hierarchies to achieve this.
Paul.
@mrommala Hey Mate,
You can use this method.
from 2 : you can go down in list . country -->city -->state -->zip code.
You can remove state from row if you do not want to drill down to state level
Hello @mrommala,
Well, I donât think so this type of conditional drilling is available where if itâs USA then Country >> State >> Postal Code and for Other Countries, Countries >> City >> Postal Code. This is because under the âLocationâ section we donât individual sections available for such types. But what you can simply do is use the âBookmarks and Buttonsâ technique for this type of condition. Below are the screenshots provided for the reference for both the conditions -
A. USA Visual -
1.1. Overall USA Visual
1.2. USA >> States Visual
1.3. USA >> States >> Zip Codes Visual
Similarly, now for other countries, replace the States field with the Cities field -
B. Other Countries Visual
1.1. Other Countries Visual
1.2. Other Countries >> Cities Visual
1.3. Other Countries >> Cities >> Zip Codes Visual
Iâm also attaching the Excel as well PBIX file of the working for the reference.
Hoping you find this useful and meets your requirements that youâve been looking for.
Thanks and Warm Regards,
Harsh
Map Visual With Drill Down - Harsh.xlsx (9.9 KB)
Map Visual With Drill Down - Harsh.pbix (27.9 KB)
Hi @mrommala, weâve noticed that no response has been received from you since the 23rd of October. We just want to check if you still need further help with this post? In case there wonât be any activity on it in the next few days, weâll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
@Harsh, @samharishk, @Paul , @EnterpriseDNA
Thank you very much for your valuable time.
I followed below approach to fulfill my requirement.
Initially, I have created calculated column (sub_location) as below:
sub_location = IF(ârpt spt_client_product_detailâ[country]=âUNITED STATESâ,ârpt spt_client_product_detailâ[state],ârpt spt_client_product_detailâ[city])
and then used this hierarchy in map visual countryâ> sub_locationâ> zip_code.
Regards,
Madhan Rommala
Hi, if that works to solve your question, great. Initially I did the same thing, albeit in PowerQuery, but I did not realise that this was what you were looking for and went to see if multiple hierarchies would be the answer.
Hi @mrommala, a response on this post has been tagged as âSolutionâ. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!
Harsh,
I had to dig deep in my libraries to find another solution, that I had at the back of my mind. It is not mine and I do not recall who posted this.Variable Legend.pbix (63.3 KB)
Also check
Paul
