Map feature not working anymore
Can someone tell me why my Map isn’t displaying anything anymore? I was working on this yesterday and it worked fine. But for some reason the Map visualization doesn’t work anymore. Any advice?
Yusuf
@YusufGillani Thanks for posting the question on the forum. The solution can be provided efficiently and effectively if you can share your pbix file. It’s difficult to determine the problem without looking into detail.
Thanks.
Hi @YusufGillani. Back when I was on-site consulting, this unfortunately often happened to me when I was on a flaky connection; Power BI uses Bing for mapping, so if there’s an internet connection issue, perhaps that’s the cause.
Yes it works now. I think it was a disconnection between my internet and Bing.
