M Code to extract between characters that are not same position
Hi all,
Does anyone know how to extract the year from this text string? I trired “Text Extraction” and “Delimiter” but it is not coming out the way I want.
I want the year in one column but I am also showing “Gen”.
Thank you for your help
Hi @ysherriff ,
One question - if Gen-YYYY format is fix you can use
Split by Delimiter - custom delimiter like:
And then Split by Delimiter - by position (4 digits for year) :
Pbix Example:
Sample_for_ysherriff.pbix (17.3 KB)
Sample1.xlsx (8.6 KB)
@ysherriff You can use this: ysherriff.pbix (25.3 KB)
let
    Source = Table.FromRows (
        Json.Document (
            Binary.Decompress (
                Binary.FromText (
                    "i45Wck/N0zUyMDTSdczJUQhOTVeK1cEh6JSTn64LkTEy0nX3DcAlGgsA",
                    BinaryEncoding.Base64
                Compression.Deflate
        let
            _t = ( ( type nullable text ) meta [ Serialized.Text = true ] )
        in
            type table [ #"Campaign Name" = _t ]
    ChangedType = Table.TransformColumnTypes ( Source, { { "Campaign Name", type text } } ),
    AddedCustom =
        Table.AddColumn (
            ChangedType,
            "Custom",
            each
            Number.From (
                List.Select (
                    Text.Split ( _[Campaign Name], "-" ),
                    each Value.Is ( Value.FromText ( _ ), Int64.Type )
                ){0}
            Int64.Type
in
    AddedCustom
Another option:
Table.AddColumn (
    ChangedType,
    "Custom",
    each List.RemoveNulls (
        List.Transform (
            each try Number.From ( _ ) otherwise null
    ){0},
    Int64.Type
Perfect Mr. Sharma. Much appreciated.
And thanks for your willingness to help mspanic. Much appreciated
