M-Code Text.Contains Between two tables
Hi @Melissa ,
Using the mcode I would like to return the category from “refence” table instead of using if statement.
At the moment I used the below code:
if Text.Contains([Desc], “bank fee”) then “Finance” else if Text.Contains([Desc], “fire call”) then “Fire” else if Text.Contains([Desc], “deposit”) then “Finance” else 0)
I would like to replace the above with Text.Contains using other table “Refence”
If we would look for an exact match we could use the below:
Refence{[Code=[Desc]]}[Category]
Could you please advise?
Please find the attached excel files.
Test File.xlsx (19.2 KB)
Decription.xlsx (8.3 KB)
Reference.xlsx (9.2 KB)
Thank you Matty
Hi @Matty,
Give this a go. You can avoid hard coding and multiple if-statements.
Note I’m also ignoring case.
here’s your sample file. eDNA - TextContains lookup.pbix (18.1 KB)
I hope this is helpful.
Thank you @Melissa !
WOW your formula ignores the extra step that I applied → transforming everything to lower case.
I am geussing “Comparer.OrdinalIgnoreCase” → ingore case sensitivity .
What does it do the question mark “?” at the end of the formula?
Hi @Matty,
Q1 =Yes, and Q2 for that you can review, this video.
Thank you @Melissa :slight_smile: M=Melissa Code :smiley:
@Melissa
Hi Meliisa,
I did replicate your code, but run into small issue:
the question mark didn’t worked in PQ (Excel) correctly it returns error instead of null.
What is the reason behind it?
My guess would be you don’t have a BufferReference table?
Hard to trouble-shoot with just this picture
@Melissa
I do have BufferTable,
The error that I get using:
Table.SelectRows(BufferReference, (IT) => Text.Contains([Description],IT[Description],Comparer.OrdinalIgnoreCase)){0}[Allocation]?, type text )
The code is returning the result, but if the allocation doesn’t exist in the lookup table then it returns an error.
I tried other two solutions that I thought might work:
Using “otherwise”
Table.SelectRows(BufferReference, (IT) => Text.Contains([Description],IT[Description],Comparer.OrdinalIgnoreCase)){0}[Allocation]? ,otherwise null, type text )
Then I thought I could wrap the function using “Table.ReplaceErrorValues” but again it didn’t work:
Table.ReplaceErrorValues(Table.SelectRows(BufferReference, (IT) => Text.Contains([Description],IT[Description],Comparer.OrdinalIgnoreCase)){0}[Allocation]? , type text ))
Did you also include the try clause?
each try Table.SelectRows(BufferReference, (IT) => Text.Contains([Description],IT[Description],Comparer.OrdinalIgnoreCase)){0}[Allocation]?, otherwise null
Thank you @Melissa it worked now!!
each try Table.SelectRows(BufferReference, (IT) => Text.Contains([Description],IT[Description],Comparer.OrdinalIgnoreCase)){0}[Allocation]? otherwise null, type text )
