Hello,
I am seeking for help regarding running totals as I am unable to create them my data is slightly different and it does not work as per video from YouTube from:
or
I would appreciate if you help me to resolve two slightly different scenarios:
- The data is stored in Table, I have manage to sort data by date and add Index Column to the table using the below m-code:
Table.Sort([All Rows],{{“TransactionDate”,Order.Ascending}}),
Table.AddIndexColumn([SortedTable], “Index”, 1, 1, Int64.Type)
After that I expand all the data, there are a lot of different columns but the only needed for tunning totals are as per below ChequeValue and Index:
For running Totals I tried the below formula:
List.Sum(List.FirstN(“Index”[ChequeCurrency],[Index]))
but I get an error:
“Expression.Error: We cannot apply field access to the type Text.
Details:
Value=Index
Key=ChequeCurrency”
And I am not sure how to fix it.
- Approach I used the code as per described in the below yt:
(funcition):
But the formula/fuction does not work correctly as the Custom Table is adding the whole index as one total so for one table it could be 0, for other it could be 43,21 and other 5892 whereas it should technically work as running total but it does not.
Instead of using the fiction as per YT I tried to add on my own cumulative total to each table with the below mcode:
Table.AddColumn([SortedTable], “RunningTotal”, each List.Sum(List.FirstN(“SortedTable”[ChequeValue], [Index])), Int64.Type)
but I get an error
Details:
Value=SortedTable
Key=ChequeValue
Could you please advise??
@BrianJulius
