Hi DNA Team,
I thought to calculate working days in m code I will need to use one maybe two m-codes.
I manage to find the formula on youtube after 30 minutes;
(InitialDate as date, FinalDate as date ) as number =>
let
DaysBetweenDates = Duration.Days(FinalDate-InitialDate),
DaysList = List.Dates(List.Min({InitialDate,FinalDate}),Number.Abs(DaysBetweenDates)+1, Duration.From(1)),
WeekDaysList = List.Select(DaysList, each (Date.DayOfWeek(_, Day.Monday) < 5) ),
WorkingDays = (if DaysBetweenDates < 0 then -1 else 1) * List.Count(WeekDaysList)
in
WorkingDays
I tried to split each section to have a better understanding. I will appreciate if you could confirm if my thinking is correct ish:
1.(InitialDate as date, FinalDate as date ) as number =>
// This part of the function will be used in Add Columns → invoke functions
- DaysBetweenDates = Duration.Days(FinalDate-InitialDate),
// works as DateDiff calculate the number of days between two dates
3.DaysList = List.Dates(List.Min({InitialDate,FinalDate}),Number.Abs(DaysBetweenDates)+1, Duration.From(1)),
//This function creates a list from itial date to final date and adds 1 to days between (for example 16/10/2020 - 16/10/2020 will equals 1 day)
4.WeekDaysList = List.Select(DaysList, each (Date.DayOfWeek(_, Day.Monday) < 5) ),
//indentifies weekends if weekday is greater than 5
5.WorkingDays = (if DaysBetweenDates < 0 then -1 else 1) * List.Count(WeekDaysList)
//List.Count(WeekDaysList) counts how many weekends days there are
I am a bit confused about where the m code formula calculates the working days.
For Example:
05/10/2020 - 16/10/2020
10 workings days, I am trying to find in the m code where the formula do calculation 12 -2 =10
I will appreciate your help DNA Team
