I’m looking to find a lost customers … but first i want catogirized the purchase patterns (daily, Weekly, Monthly, Trimestre, Semester, Anual…), then calculate if the customer lost or not baset on his purchase frequency …
To help move this along please provide a sample PBIX file with the progress you’ve already made.
Furthermore a mock-up of the disired results and how you intend to visualize that will be helpful as well.
Thanks for posting your question @mkadmich.abdelaziz. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
Hi @mkadmich.abdelaziz, we’ve noticed that no response has been received from you since the 11th of October. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
