How to perform a lookup operation in power query?
sample 11_4.pbix (45.9 KB)
Please find the attached file.
I would like to implement this logic in power query:
Cashflow Category_ES_CP =
VAR lookup =
LOOKUPVALUE (
âLookup Table 1â[Value],
âLookup Table 1â[Location Code], âReceivablesâ[Location Code]
VAR Category =
IF (
lookup = â100â,
âCash from Existing Salesâ,
IF (
lookup = â200â,
âCash from inventory salesâ,
IF ( lookup = â300â, âCash from new launchesâ, âOthersâ )
IF (
âReceivablesâ[Cashflow Category] = âCash from Existing Salesâ
|| âReceivablesâ[Cashflow Category] = âCash from completed projectsâ,
Category,
LOOKUPVALUE (
âLookup Table 2â[Category],
âLookup Table 2â[Location Code], âReceivablesâ[Location Code]
Hi @Anu,
There are many ways to look things up in M, but give this a go.
AddCategory = Table.AddColumn(#"Changed Type", "Custom", each
let
lookup = BufferLookup1{[Location Code = [Location Code]]}?,
Cat1 = if lookup <> null then
if lookup[Value] = "100" then "Cash from Existing Sales"
else if lookup[Value] = "200" then "Cash from inventory sales"
else if lookup[Value] = "300" then "Cash from new launches"
else "Others"
else null,
Cat2 = try BufferLookup2{[Location Code = [Location Code]]}[Category] otherwise null
in
if [Category] = "Cash from Existing Sales" or [Category] = "Cash from completed projects" then Cat1
else Cat2,
type text
the result.
Hereâs your sample file. sample 11_4.pbix (47.8 KB)
I hope this is helpful.
could you please explain this part a little?
let
lookup = BufferLookup1{[Location Code = [Location Code]]}?, // get matching Record else null
Cat1 = if lookup <> null then // if not null (so there is a matching Record)
else "Others"
else null,
Cat2 = try BufferLookup2{[Location Code = [Location Code]]}[Category] otherwise null // get matching Record field value otherwise null
in
else Cat2,
type text
try BufferLookup2 , could you please explain âtryâ
@Anu You should google and try to find what a certain function does, Melissa wonât be able answer everything.
Few days ago I saw her writing â?â after a line of code and instead of asking her I googled and found articles/answers and video that explained that it is used to prevent errors and return null.
Thatâs how you will learn.
Hi @Anu, did the response provided by the users and experts help you solve your query?
If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @Anu, weâve noticed that no response has been received from you since the 11th of April. We just want to check if you still need further help with this post?
In case there wonât be any activity on it in the next few days, weâll be tagging this post as Solved.
Hi @Anu, due to inactivity, a response on this post has been tagged as âSolutionâ. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
Weâve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
