Looking for how users are currently connecting to the Xero App since the removal of the Microsoft Connector earlier this year from Power BI.
Looking for low cost options preferred, any help would be appreciated.
just to be certain that all options are explored, I feel I have to mention that Xero has a handful of apps listed on their own website that integrate well between Xero and Power Bi
DISCAIMER: I have not used any of these, and have only explored cost based on clicking the âGet this Appâ button on the Xero website.
The above info is listed here: https://apps.xero.com/us/collection/powerbi
Regarding the official connector, apparently it was Xero that removed that, and other than âlow usage levelsâ no reason was given. One user in 2022 (July 6th to be exact) did ask how to connect Xero to PowerBI, and the response on the forum was to raise a ticket with the support team so âwe can give you a hand hereâ.
I did find a couple of companies that advertise connectors for Xero and PowerBi (search: Power BI Xero Connector) - but as I have not used any of them, I really cannot make any recommendations. Also, as with most of these types of connectors, they require contact with the company making the request before providing any type of quote. ![]()
We have been using SyncHub to access our xero data for a while now (maybe 3 years) works very well, never had a problem with it.
Thank you for your reply - I will take a look
Thank you for your detailed reply - I did do some reading one those apps as well, may the odata is worth a try
Good luck with your hunt, I know it can be frustrating to lose access to a tool your team has come to depend on.
Hi @dalexander, did the response provided by other Forum members help in solving your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @dalexander, due to inactivity, a response on this post has been tagged as âSolutionâ. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
