Hi everyone, I have a fact table with ID, Vender, Date, and Balance. I have a measure that adds a label to each row, and the rows with the max date are labeled as “Active”, rows that intersect with approved table are “Approved”, and everything else should be “canceled”.
“Canceled” is not working, as it creates an extremely large table with all rows labeled “canceled”.
HI @gersch.schiff
Just a question, are you using the EDNA date table? I would recommend that you use a separate date table instead of using your date item in your fact table.
The information in the bottom is using a separate date table
Don’t forget to mark your date table as a date table.
Hi @Keith , thanks for your response!
Yes, I always use EDNA date table in all my reports.
The bottom sample is something I found online as it seemed like it could be aligned to what I’m trying to accomplish, but I’m not sure. Maybe I should remove it from this post?
And yes, the date table is marked as the date table.
ok, I changed the calculated column to a measure and expanded it to include the three labels I need, however, only 2 out of 3 works, “canceled” is not working:
We notice that no response was received from you on the post above.
We are waiting for your masked demo pbix file and other supporting links and details so other users can help you in your query.
Due to your inactivity, we’ll be tagging this post as Solved.
As a suggestion, please start a new thread with the updated details and your PBIX file.
This way, our experts and other community members will have access to the most recent information and be able to offer potential solutions more easily.
