Hello Everyone,
I am using a KPI tile that contains time intelligence calculation (Month to date), and I need to add a static value as a target but I can’t find a way to do it properly.
What I did so far is create an aditional measure -with the following syntax (If [Measure ] > 0.00, 50.00, BLANK() -for the target but when placed in the visual the target shows ‘‘blank’’.
This is probably an easy fix but I am running out of ideas.
Thank you,
Cédric
