Hi, I couldn’t figure out how to create kpi traffic lights for -ve number variance and -ve % variance. The rule only allows +ve range and rejects my -ve number and percentage. Could you please help? Many thanks Christine
Have you tried this?
Could you also provide an image? This will help to pinpoint what exact problem you have.
Thanks for posting your question @HudsonC. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
Hi @HudsonC, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!
Thanks I will give this a go
