Keeping a filter associated with a measure
I have a challenge with trying maintain a value from a measure that uses a filter to grab a value that is needed for a simple math calculation.
The goal:
For all departments in a table. If the selected year is 2021, go back to December 2020, find the needed value for each department and return it, take that value and subtract it from the current value associated in 2021 and display the difference. I have to do this because of the way data is coming from our ERP. I was able to get it to work creating a custom column in power query, but the issue was that I used hard coded values. All good till data changes in 2020 needed to be made. Needless to say my numbers no longer worked. The solution to grab the value from last year. That way if changes are made it will handle the calc with updated values.
I have gotten it to work for one specific department I then subtract the value from another measure. In this specific case I am using the measure 2020 Sales which apply the returned value to all departments. I am still failing at getting this to work for all departments listed in the visual. Any help is appreciated.
Below are the two associated measure.
December 2020 Sales =
CALCULATE (
SUM ( ‘Account Schedule’[Balance_at_Date_Actual] ),
FILTER (
ALL ( ‘Account Schedule’ ),
‘Account Schedule’[KPI_Code] = “70”
&& ‘Account Schedule’[Date] = DATE ( 2020, 12, 01 )
RD Sales YTD =
CALCULATE (
SUM ( ‘Account Schedule’[Balance_at_Date_Actual] ) - [December 2020 Sales],
FILTER ( ‘Account Schedule’, ‘Account Schedule’[KPI_Code] = “70” )
Daily Doc01262021.pbix (444.9 KB)
Can anyone assist with this topic?
@lomorris,
Sorry - forum has been unusually busy over the last few days, and a lot of us have been focused heavily on finishing our Data Challenge entries. I’ll be glad to take a look at this one later tonight - looks interesting…
No problem Brian, totally understand. Looking forward to learning more from you and resolving this challenge. I feel that I am really close.
@lomorris See if this works: Daily Doc01262021.pbix (439.3 KB)
Total Balance =
VAR CurrentBalance =
    SUM ( 'Account Schedule'[Balance_at_Date_Actual] )
    IF ( NOT CurrentBalance = 0, CurrentBalance )
VAR CurrentYearMonth = "Dec 2020"
VAR Result =
    CALCULATE (
        [Total Balance],
        'Account Schedule'[KPI_Code] = "70",
        Dates[MonthInCalendar] = CurrentYearMonth,
        REMOVEFILTERS ( 'Account Schedule' ),
        VALUES ( 'Account Schedule'[Dept.] )
    Result
RD Sales YTD 2 =
IF (
    ISFILTERED ( Dates[Year] )
        && SELECTEDVALUE ( Dates[Year] ) = "2021",
        [Total Balance] - [December 2020 Sales]
@lomorris,
I was working on this one as well at the same time and came up with very different results, since it seems to me that the Balance at Date Actual in both calculations should be calculated as a MAX and not a SUM, since the figures are already cumulative. My #s match the Richmond table in your example, so I think I may be on the right track here, but please confirm:
 Prev Dec Sales by Department =
VAR CurrYr = YEAR( TODAY() )
VAR PrevDec = DATE( CurrYr - 1, 12, 01 )
VAR SelDept =  SELECTEDVALUE( 'Account Schedule'[Dept.] )
VAR Result =
CALCULATE (
    MAX( 'Account Schedule'[Balance_at_Date_Actual] ),
    FILTER (
        ALL ( 'Account Schedule' ),
        'Account Schedule'[KPI_Code] = "70" &&
       'Account Schedule'[Date] = PrevDec &&
        'Account Schedule'[Dept.] = SelDept
Result
RD Bal Max Today =
VAR MaxDate =
    MAX( 'Account Schedule'[Date] ),
    REMOVEFILTERS( 'Account Schedule'[Date]  ),
    'Account Schedule'[Date] <= TODAY()
VAR RDBal =
    MAX( 'Account Schedule'[Balance_at_Date_Actual]),
    FILTER ( ALL('Account Schedule'),
        'Account Schedule'[Date] = MaxDate &&
RDBal
RD YTD =
[RD Bal Max Today] - [Prev Dec Sales by Department]
I hope this is helpful - full solution file posted below.
P,S. Always be sure to mark your Dates table as a date table, esp. when you’re dealing with time intelligence.
Antriksh, thanks so much for your proposed solution. Unfortunately the results were not what I was expecting as suggested by Brian J below which is exactly the result I was expecting to see. I really do appreciate you taking the time to look at my challenge. Thanks Again.
Brian, This is exactly what I was looking for albeit more complexed then I expected, I though it was some very simple thing I was overlooking. My next steps are to review all lines of each measure to get clear on exactly what line of Dax is doing and apply that to the other department measures, and to also mark my dates table as a date table. Once again you have shown how valuable this forum is. I have taken a number your suggestions into our company’s business reporting and will most certainly use this.
Thanks Again!
No problem, I must have misunderstood the requirement.
Brian, one quick question with your solution. When I applied the measures there are two things that I noticed that are side effects that I am looking at but thought I would ask about.
  • I noticed when I pick another month outside if the current month the say I look at Feb 2021 the YTD numbers are incorrect in that the numbers shown are from December 2020 when they should be the YTD from the previous month. I am thinking that this is just an conditional statement I can knock out. I should be able do that with no problem.
  • I also saw that the RD YTD measure shows the correct numbers but does not Total at the bottom of the column. I am looking at that too.
You may have a quick answer, but I am looking into it for sure. I have added a screenshot of both situations and included the pbix file you sent me.
Thanks again for your support.
eDNA Forum Daily Doc01262021 – solution.pbix (435.6 KB)
@lomorris,
Both of these should be pretty easy fixes. For the first one, I assumed that the RD Max Bal measure would always calculate with the maximum date of TODAY(). However, to change that based on the slicer, you would just need to harvest the value of that slicer and replace the TODAY function with that harvested value.
In terms of fixing totals, that is an extremely common issue with DAX measures. DAX will usually attempt to make a guess (often wrong), but in the case of multiple nested measures will sometimes as in this case just throw a blank, which is the DAX equivalent of ¯_(ツ)_/¯
Enterprise DNA expert @Greg has put together a phenomenal compendium in the DAX Patterns section of the forum on how to fix this problem. Take a look, give it a go, and if you have any problems just give a shout.
Brian,
Worked as expected. I was able to as you suggested harvest the date, and get the correct numbers back whether moving forward or backward on the date slicer. The Dax patterns that Greg posted also gave me what I needed to get the needed totals to display. Now is just some cleanup of my Dax.
Thanks again. I am now able to move this into production.
@lomorris,
Great to hear you’re all set now. Enjoyed working with you on this one.
Good luck with the project!
