I have created a Power BI report where the background is an image. We are using Power BI Embedded to show our Power BI reports on our Internal web page.
The problem is, that when I Embed the Report, the background image is not shown.
I could not find anything on how to solve this? Or if it is possible at all?
Anyone who knows how to do it?
I also searched to find the exact issue but no luck. My suggestion will be to raise a Ticket at Power BI Support site. They shall be able to help you with this problem.
Hi @JNordentoft, did the response provided by @ankit help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @JNordentoft, we’ve noticed that no response has been received from you since the 26th of May. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @JNordentoft, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
