Issues with Totals for Dax Measure
Hi all,
I have a DAX measure which is giving me the results for each row as expected, but at the end it should also give me the totals, so in this case 42.18.
I have looked at the forum to find a solution, but whatever I tried, it all returns a total of 0,00 in the end.
This is the measure:
Marge issue =
IF(
[DGM %] < 0.49,
[Commission]*-1, BLANK() )
This is what i have tried so far:
Marge 2 =
SUMX(
ADDCOLUMNS(
VALUES
(‘Clients Thomas’[Code]),
“Client” , ‘Clients Thomas’[Code],
“Margin Corr” , [Marge issue] ),
[Marge issue]
Marge 3 =
IF(
HASONEVALUE( ‘Clients Thomas’[Code]),
[Marge issue],
SUMX(
ADDCOLUMNS(
VALUES( ‘Clients Thomas’[Code]),
“Marge issue”, [Marge issue]
[Marge issue]
and this one:
Marge 4 = SUMX
(SUMMARIZE(
‘Clients Thomas’,
[Marge issue])
It would be great if somebody can help me to get this fixed…
Many thanks!!
please see if this post from @Greg will help to steer you in the right direction
if this does not help, then please provide a sample file that forum members can use to try to help you solve your issue.
@marieke
What is [DGM %] at the grand total?
Hi @Heather
Thank you, I know about that topic from Brian and have tried several of his solutions, but without any luck unfortunatelly…
I have attached a copy of the PBI file, it would be great if somebody knows how to fix this…
Sale Commission Thomas Dummy.pbix (743.9 KB)
Hi @AntrikshSharma
I have now attached a copy of the file to make things more clear…(hopefully)
Hello @marieke,
To achieve the results of “Grand Totals” below is the formula alongwith the screenshot of the result provided for the reference -
Marge - Harsh =
SUMX(
    SUMMARIZE(
        VerkoopFacturen ,
        'Clients Thomas'[Code] ,
        Debiteuren[KlantNaam] ,
        VerkoopFacturen[FactuurNummer] ,
        VerkoopFacturen[FactuurRegel] ,
        "Totals" ,
    [Marge issue] ) ,
[Totals] )
And if you want to convert the numbers and totals into the postive from negative than just use “ABS()” function. Below is the formula and screenshot of the result provided for the reference -
Marge - Harsh =
SUMX(
    SUMMARIZE(
        VerkoopFacturen ,
        "Totals" ,
    ABS( [Marge issue] ) ) ,
[Totals] )
Also attaching the working of the PBIX file for the reference.
Note: The figure is off by 0.01 and this could due to decimal formatting. If we move the decimal portion to 3 places than we get the results as 42.187.
Thanks and Warm Regards,
Harsh
Sale Commission Thomas Dummy.pbix (743.5 KB)
@marieke,
I was working this one at the same time as @Harsh, and came up with a nearly identical solution:
Marg Issue2 =
VAR Result =
    SUMX (
        ADDCOLUMNS (
            SUMMARIZE (
                'VerkoopFacturen',
                'Clients Thomas'[Code],
                'Debiteuren'[KlantNaam],
                'VerkoopFacturen'[FactuurNummer],
                'VerkoopFacturen'[FactuurRegel]
            "@BaseMeas", [Marge issue]
        [@Basemeas]
    Result
My solution does have one important difference - when adding extension columns to a table, it is a best practice to do so using ADDCOLUMNS, rather than SUMMARIZE.
I hope this is helpful.
Hi @BrianJ and @Harsh ,
Many thanks for the solutions you both provided, they both works fine, I have decided to use the version from Brian with the ADDCOLUMNS…
Many thanks for your help with this!
Kind regards Marieke
