I am computing values in Power Bi using the ISINSCOPE function but not getting the expected result in my total.
As the image above shows, my values come out correctly in rows but not in the group total or grand total.
I have a measure like so:
Planned Session Duration =
IF (
ISINSCOPE( DeltaRoom[DeltaRoomCode] ) && ISINSCOPE( xDate[Date] ),
CALCULATE( MAX( 'Isinscope'[PlannedSessionDuration] ) ), -- get the max planned session duration for this scope
IF (
ISINSCOPE( Consultant[ConsultantKey] ) && ISINSCOPE( xDate[Date] ),
CALCULATE( MAX( 'Isinscope'[PlannedSessionDuration] ) ), -- get the max planned session --duration for this scope
IF (
ISINSCOPE( Agency[AgencyName] ) && ISINSCOPE( xDate[Date] ),
VAR _PlannedSession =
SUMMARIZE(
'Isinscope',
'Isinscope'[Date],
"PlannedSessionDuration", MAX( 'Isinscope'[PlannedSessionDuration] ) -- get the max value for the scope
SUMX( _PlannedSession, [PlannedSessionDuration] ) -- return the sum of the max value from the variable to get the total
Not sure where I am getting it wrong. What I hope to achieve is to get the MAX value of PlannedSessionDuration for each row. The MAX value of each row should be summed up as the total per group in the scope so Efficiency is computed like so:
Efficiency =
DIVIDE(
[Planned Duration(Mins)],
[Planned Session Duration]
I have attached the file.
Isinscope.pbix (137.5 KB)
Isinscope_Data.csv (106.5 KB)
I really appreciate any help you can provide.
