Issue with funnel chart using Deneb
Hi All,
I’m trying to use Deneb to build a funnel chart.
I was able to build a template using internal data.
A template with internal data shows exactly what I need. Simple but effective.
Issues come when I try to replace internal data with data from a dataset.
The problem seems to be on Y and Y2 calculation. They seem correct but they are not.
This is the simple dataset from Power BI
I’m attaching the two templates hoping for some help.
Thanks,
Roberto
not_working_template.txt (1.2 KB)
working_template.txt (1.7 KB)
Hi @Roberto. My first thoughts are its a data or modelling issue. Please upload your work-in-progress PBIX with sample or obfuscated data and I’ll pursue further.
Hi @Greg,
I’ve removed all data but that is required for the visualization.
Applying the template I got the same result.
I’m trying to learn how to use Deneb, and your course has been very useful.
I’d like to foster Deneb in my team, but before I need to get some confidence.
Thanks for your help.
Regards,
Roberto
funnel deneb.pbix (1.3 MB)
Hi @Roberto.
I used the heat lane example from the Vega-Lite website as a reference and came up with this:
The main issue was that you were not using ranged bars (i.e., with both y and y2 values) around a middle value. Once the calculations were made, the encoding was adjusted accordingly.
Hope this helps.
eDNA Forum - Deneb Heat Lane.pbix (1.3 MB)
