Issue with formatting in Tabular Editor 3.0
Hello everyone,
Format String Expression is not working when I try to set it.
Formatstringpercent
Giving me the following name conflict error.
Did anyone see this problem before?
So, as a work around, I used FORMAT() function in the calculation item code to make it work. I would like to use format string expression if possible.
Hi there,
I looks like the issue is your naming of your data field. Your measure can’t use a similar name like format as its reserved for internal use within the power bi commands.
Please check all your data field names/calculated fields. Also make sure your data fields are setup correctly (data type).
Without seeing your data model, we can’t really see what you are doing.
thanks
Keith
Hi @svada, possible to send your working PBIX file to help Keith and other members see the scenario better? Providing one will help users and experts find a solution to your inquiry faster and better.
Sure. Will upload my PBIX File soon. Thank you
Hello @svada. A gentle follow up on your PBIX file.
Hope to hear back from you :slight_smile:
Hi @svada, we’ve noticed that no response has been received from you since October 22.
We waited for the masked demo pbix file, and any other supporting links and details.
Due to inactivity, we’ll be tagging this post as Solved.
