Hi Team,
This is not a Tactical question as such no PBIX has been attached.
It s a Strategic or BI arch question on Power query for Business Intelligence projects within a large enterprise settings/Product.
Let me set the context here , as I herd and agree , Power Query is the most affortable , verstile sort of ETL tool in Business scenario where Product is simple , May be it has 1-3 integrations , a Databases etc where we can get the data etl using power query and create models in Power BI (Pls correct this assumption if need)
[Scenario where the question is applicble ]
However, I am only referring to large scale products , You can consider eg of Amazon UI, Order Processing system , Order fullfillment system etc.-The architectural structure is comples with multiple interfaces or multiple integration with different(independent) systems
Long story short -What I have noticed in such products, we need to integrate data from different sources using Standard ETL Tools like (Informatica, SSIS, Talend etc) into a Data warehouse (eg. Tera data etc or similar)
From the Dawarehouse usually OLAP Cube is created in SSAS
Now we can Connect to Cube using Power BI to build reports .
Side Note : Please see -above comments might not be precise, so pleasefeel free to correct me if you got my intention behind the question below - I am not or never worked professionally as BI Professional , Its my hobbie that I am learing Power BI.
However I do work with BI Team for reporting requirements that I create for my product.
[Question context begins]
What keeps me wandering is that -There are huge now of Power Query questions either in Enda forum or otherwis public microsoft forum , certianly Power query has some sort of holy grail capability.
At the same time, on the other hand, I have never herd such Products using Power Query.
(Pls note : Pls dont get emotional
, I already admitted power query is definitely a famous tool, but only I have not seen being used in large projects ; so i want to reaffirm if this observation is valid or not via this thead)
[So exactly once again my question is ]
Qn 1 )In the example scenario mentioned have - Do company use Power Query ?
1a) If your answer is yes , then pls clarify at what stage of BI lifecycle
e.g From Data ware house to SSAS cube
or from Source to Data Warehouse.
1b) Can you pls clarify if Power query can integrate data from multiple heterogenous sources -Different data bases -SQL +NOSQL etc
