Is it possible to create Dynamic Matrix with Custom Date Fields?
Is it possible to create the Dynamic matrix with custom date fields? I came across the issue where i need to pull the multiple measures into the matrix where they needs to plotted over different custom date columns. For reference please find the below excel table which is the replica of a table i need to build in Power BI.
Note : The yellow highlighted shows the information on the columns and rows.
The values of “Sales”, “Quantity”, “YoY”,etc are coming from different tables.
Bumping this post for more visibility from our experts and users.
Hi @Suyog.
I noticed you didn’t provide a PBIX file. Providing one will help users and experts find a solution to your inquiry faster and better.
  • A clear explanation of the problem you are experiencing
  • A mockup of the results you want to achieve
  • Your current work-in-progress PBIX file
  • Your underlying data file (to allow us to go into Power Query if necessary to transform your data and/or data model – often DAX questions really end up being data modeling solutions)
Thank you!
