Is there a way to get values in blank cells using the power query?
condition - Columns and rows are dynamic. Column ‘A’ is static.
Column “A” will be always the starting point. “B” & “C” may be blank.
looking for a solution using the Power M language.
What is the logic for determining the values that should go into the blank cells?
Interpolation or Forecast method. This is possible in excel but looking for power query method.
What the logic in Excel that you are using?
Using formula “Forecast.Linear”
Answer:
Hi @TS1,
Copy this M code into a new blank query.
let
Source = Table.FromColumns(
{1,3,4,5,6.6,8.2},
{21, 4,7,9,null, null},
{33, 6,8,11,null, null}
type table[A=number, B=number, C=number]
fx = ( tbl as table) =>
let
colNames = Table.ColumnNames(tbl),
calc = List.Accumulate(
{0..List.Count(colNames)-1},
tbl,
(s, i)=> if List.PositionOf( colNames, colNames{i} ) >0
then let
basePos = List.PositionOf( colNames, colNames{i-1} ),
intPos = List.PositionOf( colNames, colNames{i} ),
toCols = Table.ToColumns( s ),
l = List.Buffer( toCols{basePos} ),
r = List.Buffer( toCols{intPos} ),
int = List.Generate(
()=> [a = l, c = List.PositionOf(r, null), b = List.ReplaceRange(r, c, 1, { r{c-2}+(l{c}-l{c-2})*(r{c-1}-r{c-2})/(l{c-1}-l{c-2}) } ) ],
each [c] >= 2,
each [a = [a], c = List.PositionOf([b], null), b = List.ReplaceRange([b], c, 1, { [b]{c-2}+([a]{c}-[a]{c-2})*([b]{c-1}-[b]{c-2})/([a]{c-1}-[a]{c-2}) } ) ],
each [b]
t = Value.ReplaceType( Table.FromColumns( List.ReplaceRange( toCols, intPos, 1, { List.Last(int)}) ), Value.Type(tbl))
in
t
else s
in
calc,
interpolate = fx(Source)
in
interpolate
It’s a bit verbose but this custom function seems to do the trick. Amend to your needs.
I hope this is helpful.
