Hi All,
I was struggling with the incremental refresh option. So just wanted to check, if I have 4 tables in my model do I need add parameter on all the tables or only 1 table which has a large volume of data can be used for an incremental refresh.
As currently after putting the filter on my table which has high volume and after saving the changes when I select incremental refresh it gives a pop up to set up the parameter to data.
I’ve used the reserved keywords to setup parameters, still not able to apply this into my model.
Any idea if I’ll be doing something wrong has anyone faced similar issues while applying the same.
Ankit
