Importing geojson data into Power BI
Hi there,
I want to read “Crash analysis system” dataset hosted on the following link:
https://catalogue.data.govt.nz/dataset/crash-analysis-system-cas-data/resource/c16a0a0c-057e-4122-a7a0-9367aeb8458a
The dataset is in geojson format. I used the web option to get the data and entered the following link to read the geojson dataset:
https://opendata-nzta.opendata.arcgis.com/datasets/8d684f1841fa4dbea6afaefc8a1ba0fc_0.geojson?outSR={"latestWkid"%3A2193%2C"wkid"%3A2193}
Power BI started reading the data from the link. However, after a while it throws the following error:
I never imported geojson file into Power BI file. I am not sure where I am making the mistake. Any help to import geojson data into Power Bi would be really appreciated.
Hey @leo_89 Let me know if any of the below helps
A Quick Guide to GeoJSONs in Power BI | by Lance McDiffett | Towards Data Science
Use Shape maps in Power BI Desktop (Preview) - Power BI | Microsoft Docs
How To Create Custom Shape Maps for Power BI — DiscoverEI
Hi @DavieJoe , I tried to follow the first link of your reply but it did not work.
If the below link does not work then google the article name and you should find the link. Strange how it’s not working as it works for me.
@DavieJoe , Sorry I meant to say that I was following the article and I stuck due to the error I posted in my original post.
Hi @leo_89! We noticed that your inquiry was left unsolved for quite some time now.
