Importing data with new columns in power query
Hi there,
Let say I have two excel files with similar columns and I import these files through Power Query using the Folder method, now when I add a third file, I have an additional column. How can I add this to my appended data automatically, is there a workaround or M code manipulation that anyone knows.
Much appreciated.
Mustafa
Hi @chris786, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @chris786,
Check out this article by Chris Webb.
I hope this is helpful.
But if you need further assistance please provide a PBIX with some Sample Data files. Thanks!
Hi @chris786, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!
I think I found the solution using Excel.Workbook([Content]) custom column.
Thanks,
