Thanks for bringing this to our attention. We’ve corrected the link. Please try accessing the course again and use the updated link for the Survey Form.
If this resolves the issue, please mark this reply as the solution.
The Survey form on the link has been updated, please take a moment to try it again.
Do you have a reference of the survey form you are expecting to see? We would appreciate any feedback you have to offer, as your suggestions will help us better serve you.
Just following up if the response above help you solve your inquiry?
We’ve noticed that no response was received from you on the post above. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Due to inactivity, a response on this post has been tagged as “Solution”.
