Hi All,
I created the following formula in power query conditional column:
= Table.AddColumn(#“Removed Columns3”, “Email Filter”, each if Text.Contains([Contact Email] = “ppd.com” or “hubspot.com” or “aes.com” or “evidera.com” or “kettlercuisine.com”) then “Test Emails” else [Contact Email])
but coming with an error message:
Expression.Error: We cannot convert the value “hubspot.com” to type Logical.
Details:
Value=hubspot.com
Type=[Type]
Can someone help? What am I doing wrong?
I figured it out. I had to bracket each instance I had to add quotes around the table.
= each if Text.Contains([Domain], “ppd.com”) then “Do Not Use”
else if Text.Contains([Domain],“hubspot.com”) then “Do Not Use”
else [Domain])
glad you found the answer, thank you for coming back to the forum to post a solution for others
Glad you find the solution but if your criteria is more than two, the following M code will be shorter:
each if List.PositionOf({“ppd.com”,“hubspot.com”},[Domain])>=0 then “Do Not Use” else [Domain]
Instead of {“ppd.com”,“hubspot.com”} part, you can select any list.
Also if you want to check the items which contain your list, below M code will work:
if List.Count(Splitter.SplitTextByAnyDelimiter({“ppd.com”,“reza.com”})([Domain]))>1 then “Do Not Use” else [Domain]
