How to update Next year figure
Hi Team,
I have the following DAX for YTD Actual figures:
How can I change it to get next year data or Last year data.
Thank you.
Hi @ammu, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @ammu, we’ve noticed that no response has been received from you since the 7th of April. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi thanks for your reply.
I was able to find out the way. thank you.
Regards,
Aye
