How to speed up the Power BI Reports faster. I have a large dataset on opening the reports, refreshing and query editing it taking up the time up to 20-25 minutes. is there any way to speed up the reports faster?
Hi @dipeshkumar30, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hello @dipeshkumar30,
I’m providing below few of the links of the articles as well as videos about how to overall optimize the report.
Hoping this helps you. ![]()
Thanks and Warm Regards,
Harsh
https://towardsdatascience.com/how-i-speed-up-my-power-bi-report-5x-155255415895
Hi @dipeshkumar30, we’ve noticed that no response has been received from you since the 19th of November. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
