Hi All,
I would like to know if we can set alerts to notify when the dataset refresh is complete.
I have created a Power Automate Refresh button for the user to click to refresh the dataset on demand. However, it takes a while to refresh the dataset. So it would be good if they were notified when the refresh is complete to check the updated data.
Appreciate any guidance on this.
Regards,
Sudhir Simson
It seems that the alert is based on a piece of data (say Quantity).
You may want to set the alert to que when âQuantity > 20â or some value in your dataset that you know will always be the case. The alerts only trigger once the data is refreshed, so this option should work for users.
This site explains how to setup alerts. Hope you find this helpful.
Hi @sudhirsundar,
Iâve looked into the documentation for the power automate Power BI connector at this time there doesnât seem to be a trigger for when a dataset refresh has been completed.
Not my cup of tea (yet) but you can look into calling the REST API that does allow for Datasets - Get Refresh History which sounds promisingâŚ
I hope this is helpful
Thank you very much. I will have a look.
Thank you very much, Melissa. I will have a look.
Itâs great to know that you are making progress with your query @sudhirsundar.
Please donât forget if your question has been answered within the forum it is important to mark your thread as âsolvedâ.
We request you to kindly take time to answer the Enterprise DNA Forum User Experience Survey,We hope youâll give your insights on how we can further improve the Support forum. Thanks!
Hello @sudhirsundar itâs been a while since we got a response from you. In case there wonât be any activity on it in the next few days, weâll be tagging this post as Solved.
Hi @sudhirsundar, due to inactivity, a response on this post has been tagged as âSolutionâ. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
