Hi i want to rotate a text box for fit in slicer panel. But not able to do this.
thanks in advance.
thanks in advance.
You cannot currently rotate a textbox in native Power BI, but you can use “Text Enhancer by MAQ Software” visual from marketplace.
Other options are creating this in Word, PowerPoint or even Excel and import it as picture.
Hi @dipeshkumar30, we’ve noticed that no response has been received from you since the 19th of November. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
