I have a model which takes 30 minutes to refresh, suppose I am having changes only in one of the table , without having to refresh the entire model, is there a way to get the updated data.
I understand , I can disable the refresh for other tables., but is there any other way out there. Because I am having more than 50 tables, its again a Task to disable refresh for each of these.
Hi @Anu,
If you’ve made changes to just one table hitting Close and Load in the Query Editor will only reload that - and all tables that reference it of course.
In Desktop you can also right click an individual table to refresh that.
I hope this is helpful.
If you have more than 50 tables for an SSAS/PBI model, then there is also a data modelling problem.
How can I correct it? Most of them are mapping sheets, not actual data itself.
What do you mean by mapping sheets?
Where does that data come from?
See this course for modelling.
Hi @Anu,
Choosing a storage mode can be solution for this issue.
Based upon Radacad’s (Reza Rad) explanation, you should Push the Transformation to Dataflow.
I also think that the following articles of Chris Webb and Reza Rad can be helpful:
Hi @Anu, did the response provided by the users and experts helped you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
Hi @Anu, we’ve noticed that no response has been received from you since the 31st of December. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
