Is there an easy way to print my course plan? It would be good so I can give it to my employer. Thanks
Hi @meldon
I don’t see a way of doing that either
What you could do is highlight the text course plan and copy the highlighted and paste it in a word document. *Make sure you are not in dark mode.
You can do that with plan or individual courses.
I just clicked on see details
then select all the text (ctrl key + A)
then open up a word document and paste it into the document
or you can use Snipping Tool that is within windows but you will have to do several snips to pick up all your information.
Its work around.
I hope this helps.
Keith
Thanks Keith
