How to mute a slicer in a dashboard
Dear All,
Trust this finds us well.
Please I need clarifications on how to mute a visuals from been affected by a slicer in a dashboard pleaseee
@Dave_Adejumo,
The video below should answer your question:
https://portal.enterprisedna.co/courses/powerbisuperuserworkshop/lectures/12332246
Dave,
Click on Format on the Ribbon, then on the Edit Interactions button, then in the picture attached for each visual/table that you do not want to interact with the slicer click on the icon that has a circle with a line through it.
** Make sure you have your slicer selected like shown in the attached picture so that you get correct results**
Hi @Dave_Adejumo, we’ve noticed that no response has been received from you since January 31, 2020. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
