How to lock first few columns in matrix
I would like to start this topic by thanking @VilmarSchi who helped me getting very simple and easy to follow (compare to what I came up with) on below mentioned topic link.
Now I am wondering if there’s any way to lock first few columns in the matrix regardless which year is selected from the slicer (snip below).
Hi @AlokBhardwaj ,
Maybe you can try workaround described at:
Good luck.
Thanks @mspanic
Two things…
  1. I am using slicer to select the year to compare past data against current forecast in above is showing how to lock and scroll…
  2. I am having hard following how to put measure in column. It’s just not happing…
Alok
I used Calculation Group to solve this issue.
Thanks!
