Excel pivot tables have a Field Setting called Insert blank line after each item label.
This will add a blank row after each item in that field
Can I do this in Power BI?
I don’t think this is the solution.
She is talking about inserting blank rows in a TABLE
I want to insert blank rows in a MATRIX
Hi @BillK,
I have found this post:
Regards.
Hi @BillK, did the response provided by the @jafernandezpuga help in solving your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
