@Sebastiaan I don’t think that’s possible, also in the report that you have shared the bar isn’t hidden it will show once you switch to full screen mode.
@AntrikshSharma I see what you mean. The link I provided refers directly to the report in Power BI Service. But when you access the report from the website where it is embedded in a frame, the grey bar does not appear in full screen mode: https://innovatienul13.nl/monitoring/overzicht-locaties/
@BrianJ Unfortunately this doesn’t seem to make much of a difference. The Enterprise DNA Showcase example also has just one page visible and the others hidden and only accessible through in-report navigation.
Could there be something special the way the report was embedded in the website that makes a difference?
