Can someone please help me figure out how to get previous FISCAL month in Dax?
Thank you very much in advance!
Hi @gkhokher,
You can use the search option
in the upper right to find solved inqueries that deal with this topic. However should you require a solution for ‘your’ specific situation, you’ll need to provide a mock up PBIX with dummy data AND the expected result.
All the best.
Hello @gkhokher
Did the response from @Melissa help solve your query?
If it did, please mark her answer as the SOLUTION.
Thank you
Hello @gkhokher
Just following up if the response above help you solve your inquiry.
If it did, please mark his answer as the SOLUTION.
We’ve noticed that no response was received from you on the post above. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @gkhokher
Due to inactivity, a response on this post has been tagged as “Solution”.
We request you to kindly take time to answer the Enterprise DNA Forum User Experience Survey,.
We hope you’ll give your insights on how we can further improve the Support forum. Thanks!
